You might face an issue with integration record failed with below error
“System.Exception: Gift Certificate:'P0031' not found/map in SBO” and “System.Exception: Gift Certificate A/C is not mapped in SBO”
P0031: is a Sample GC name as per shared example, it may change from instance to instance
These errors occur when the Gift Certificate mentioned in the error line is not mapped as Retail Tender in SAP B1.
The steps are listed below:
Open SAP B1
Go to Main Menu >> choose Administration >> Add-ons >> Add-on Manager >> Start iVend Add-on.
Go to Main Menu >> choose Administration >> System Initialization >> iVend Retail >> Retail Tender.
Map the concern Gift Certificate.
Once mapped, save the changes in SAP.
Now, Retry the failed record from iVend integration failure monitor and this should sync.
