Optical Add-on issue: Few Products are not showing in the POS Error appears "No item To resolve"
6.6 with Optical Add-on
Few products (eg Color lens) are not showing at the POS. Error message appears
Observation:
All problematic products are not visible on the optical screen of the POS for the special orders. These items are visible for normal sales on the optical screen.
We analyzed the issue and found these items are visible at the standard iVend special order screen but not at the optical special order screen. These items were never visible on this screen. Below is the screenshot for the same:
Proposed Solution/Workaround:
Please make sure that these products have "Item Type" as Lens" (highlighted in the screen) for all these items, This "Item Type" field is available only in the Optical configured product screen in iVend. Below is the screenshot for the same:
Integration Error "System.Data.Odbc.OdbcException (0x80131937): ERROR [HY000] [SAP AG][LIBODBCHDB"
Environment: iVend 6.6 integrated with SAPB1 HANA Problem Statement: Integration was not working and its showing below message on Event Viewer Log “System.Data.Odbc.OdbcException (0x80131937): ERROR [HY000] [SAP AG][LIBODBCHDB DLL][HDBODBC] General ...
Gift Certicate Item not showing at POS
Problem: The gift Certificate item is not showing at POS.it is not visible at POS. Cause : Issue Comes if not following proper steps on POS. Resolution : Follow the below steps on point of sale. 1.Open the point of sale and select on item. 2.Select ...
While sending the test email it thrown error as "The SMTP server requires a secure connection"
Environment: iVend Version 6.6 Problem Statement: While sending the test email it thrown error as “The SMTP server requires a secure connection or the client was not authenticated. The server response was: 5.7.0 authentication required”. Error ...
Scan Sequence Resolution
Optical transaction Tab not showing in Ivend management console
Product version: iVend 6.6 Patch 7825 Problem statement: Optical transaction Tab not showing in ivend management console Scenario: Optical transaction TAB is not showing in ivend management console in one of the location. Observation: Checked the ...
