iVend 6.6 with SAP B1
Not able to receive a Stock Transfer in SAPB1 ErrorMessage "Not enough data"
Specific computer are not able to receive the stock transfer in SAP.
Clear the junk file from the temp folder of the computer, below are the steps to move to temp folder.
1. Go to “C:\Windows\Temp” and delete all the files. Some files may not be allowed to delete then skip those files.
2. Go to temp folder of the user profile by following the steps
a. Click the start button of your computer and write “Run”.
b. In the popup window write “%temp%” and click on “ok” button it will move to user profile temp folder.
c. Delete all the files from a folder and leave those that are not able to be deleted.
After following above steps, please close the SAP and start again. Try to save the transaction it will allow you to save stock transfer.
We also recommend to check the below point these could be the cause of error.
Check Sufficient stock is available in in-transit warehouse.
In stock transfer window it will show the quantity in “Qty. to Receive”, if it’s zero then fill the quantity and click on “ok” button.
