iVend 6.6 with SAP B1 9.2
Problem statement :
When trying to perform a stock transfer receipt of an open stock transfer that comes from a store through the AddOn option: INVENTORY -> STORE TRANSFER -> STOCK TRANSFER RECEIPT and the transfer contains a serial item, and after that when pressing "Post Receipt" button, the form throws the following error: 10000559 - "Not enough data"
It seems that there is less inventory in SAPB1 InTransit warehouse of Sending Store and Need to check the quantity in SAPB1- Intransit warehouse of Sending warehouse and compare it with iVend Enterprise .The quantities should be same at both the places .
Also suggestion would be to check integration failure log from iVend to SAPB1 for this item.
