Log in alert issue while login to handhled
while login to handheld getting an issue "handheld license count exceed"
Reason for the issue:
This issue occurs if you have already occupied all the handheld license (May you already registered the handheld device )
You can solve this issue by removing the previously registered handheld device which is no longer used.
Steps:
To remove the handheld device follow the below steps.
Go to store set-up and select "register handheld device tab "and check for the registered handheld device if it is active make it inactive and check
 the result.
Path :-administrator<<retail configuration<<store
