License not found for SAP Busisness One Integration with SAPB1 HANA
iVend 6.6 With SAPB1 HANA
Problem Statement :
There is event in Windows Event Viewer of CXSIntegration
IVEND:Connection Error:System.Exception:License not found for SAP Busisness One Integration with HANA
At the time of initialization from SAP error appear in CXSIntegration Event Viewer
Resolution/Work Around:-
Require to check below points.
1.In CXS license Tool check component of iVend_SAPB1Integration should exists like
INCREMENT iVend_SAPB1Integration_Count citixsys 5 31-oct-2021 51
2.Check User login on Enterprise Management Console so that information of license will update.
3.Check on Management Console component of Business Integration should Exists.
4.Check In CXS license Tool license should not be duplicated.
