iVend to SAP Integration Error: System.Runtime.InteropServices.COMException (0x80070008) Not enough
Environment-
IVend 6.6
iVend to SAP Integration Error: System.Runtime.InteropServices.COMException (0x80070008) Not enough storage is available to process this command
Sale Transactions is not integrating from ivend to SAP B1
Below error message shown in iVend to SAP integration failure monitor:
System.Runtime.InteropServices.COMException (0x80070008) Not enough storage is available to process this command. (Exception from HRESULT 0x80070008) at SAPbobsCOM.CompanyClass.GetBusinessObject(BoObjectTypes Object) at ReplicationSBOIntegrationWinSer.In
Reason/Cause:
This problem occurred due to CXSINTEGRATION database size was huge approx. 150400.00 MB (CXSINTEGRATION MDF Size: 19440 MB CXSINTEGRATION LDF Size: 130960 MB)
Steps are below:
- Shrink CXSINTEGRATION Database and its Logs.
- Restart iVend Integration Services
After performing above mentioned steps then checked stuck Sale Transactions get integrated successfully from iVend to SAP B1.
Make sure to have a working backup copy of the SQL database before making any changes /operation on the databases.
