Records were stuck in the integration failure monitor.
Records were failed with error "Invoice already exists with the same transaction key."
Below is the detailed exception logged in the Integration failure monitor
System.Runtime.InteropServices.COMException (0xFFFFFBA4): (101) Invoice already exists with the same transaction key.
at SAPbobsCOM.CompanyClass.EndTransaction(BoWfTransOpt endType)
at ReplicationSBOIntegrationWinSer.IntegrationObjects.LayAway.CreateLayAway(DataRow[] DSTransaction, DataSet DSTransactionSurcharge, DataSet DSTransactionPayment, DataSet DSARPayment, DataSet ObjDataSetTransactionAttribute, DataSet ObjDataSetTransactionLineAttribute, LayawayDocumentType layawayDocumentType)
The failed integration records were reviewed and it was found to be a Sales invoice. As the error says invoice already exists so the sourcekey of the failed integration record was checked in the SAP AR Invoice screen and there was already an invoice with that key. So the Error was correct. It was an SAP B1 Validation exception.
Error is coming as a duplicate record for the same Sales invoice is being tried to be posted in SAP. This generally happens when multiple integration services configured (for the same SAP database) are in running state.
1)To avoid that situation, customers need to make sure that multiple integration MUST NOT be running on the same SAP database. If there are any such instances, then there is a need to check and disable the duplicate service instances.
2)As the failed integration record was a duplicate invoice , it need not be integrated. It should be ignored from the integration failure monitor (with help of support team)
