iVend Stock transfer Code field appear blank
Product Version:
6.6 integrated with Sap B1
Customer generated stock transfer from General warehouse to retail warehouse on SAP however at the time of receiving stock transfer on store code field appears blank.
Suggest customer to configure the document number series for Document Type -Goods Receipt ST . Once it is done, restart the iVend MC to check the same.
Steps if any:
Constraints / Scenarios:
Sales Report for particular product group was appear blank
Product Version: iVend 6.6 integrated with SAPB1 Problem statement: Sales Report for particular product group was appear blank Symptoms: NA Resolution/Work Around: Check product group id if found comma on id removed the comma from product group code ...
Inventory transfer Failed to Integrate into iVend due to Product desc blank in SAP
Environment: iVend 6.6 integrated with SAPB1 Problem Statement: How to rectified product description and generate events if At the time of generate inventory transfer in SAP product of any item desc blank due to stock transfer stucked on Integration ...
UDF (No Barcode field) on Stock transfer receipt screen.
Environment iVend Version 6.6 With SAP B1 9.2 Problem Statement There is no Barcode field on Stock transfer receipt screen (Screen to receive stocks from retail warehouse) in SAP B1 as shown below so we tried to create a UDF in table of stock ...
UPC Code
UPC Codes What is a Universal Product Code (UPC)? Simply put, a UPC, short for universal product code, is a type of barcode printed on retail product packaging to aid in item identification of a particular item. It is most widely and commonly used in ...
Duplicate product code appear on Management Console
Environment: 6.5.6 SAP B1 Symptoms: Duplicate product code appear on Management Console Problem statement: Duplicate product code was showing on Product search. We noticed from these items one item is created from Enterprise and second one created ...
