Sales Report for particular product group was appear blank
Product Version:
iVend 6.6 integrated with SAPB1
Check product group id if found comma on id removed the comma from product group code through SAP.
Recommendations/Suggestion:
Suggested to not use commas on product group id.
    • Blank CSV file while exporting Sales Report
      Environment: iVend 6.6 Problem statement: When trying to export from the Sales Report to CSV, the system producing a blank CSV file. Symptoms: The process appears to work on all other reports and also works like on Excel Export. Steps: 1. select ...
    • iVend Stock transfer Code field appear blank
      Product Version: 6.6 integrated with Sap B1 Problem Statement: Customer generated stock transfer from General warehouse to retail warehouse on SAP however at the time of receiving stock transfer on store code field appears blank. Proposed Solution: ...
    • Sales Reports between items for a particular date range.
      Environment : iVend 6.6 with SAPB1 Problem Statement : Generate Sales Reports between items for a particular date range. Resolution/Work Around : Sales reports can be generated from the Management Console. Management Console >>Reports >>Sales>> Sales ...
    • Inventory Audit report showing Blank After Store Re-initialization
      Problem Statement Inventory Audit report showing Blank After Store Re-initialization Investigation Upon reviewing the issue, it was found that the inventory log data was missing in the respective SQL table. After further inspection, we identified ...
