6.5.6 SAP B1
Duplicate product code appear on Management Console
Duplicate product code was showing on Product search. We noticed from these items one item is created from Enterprise and second one created from Store by using Import Utility.
Issue is only reported on dated version iVend version 6.5 Update 6 and is not noticed on the latest branch of iVend release available for the production use so suggested to apply the latest patch from portal.
Recommendations/Suggestion:
Suggested to create product from one place either Enterprise or Store.
