iVend Addon Wrong digital signature of AddOn Citixsys AddOn uninstaller
Product Version
6.5 Update 6 integrated with Sap B1
At the time of registering the Addon in SAP its showing below message “
Wrong digital signature of AddOn Citixsys AddOn uninstaller” after upgrade.
Proposed Solution
Wrong digital signature mismatch error comes when exe version is mismatched between Server and client.
so provided the latest addon after check the version detail on .ard file
Steps
Suggest to check ivend version detail on ard file by below step
1.Go to the path C:\Program Files (x86)\CitiXsys\iVend Retail\AddOn
2.Open the latest version folder as per SAP bit version -> click on ARD file -> Open with Notepad and check version as per screenshot. It should be upgrade version.
Constraints / scenarios
Getting an error "Wrong executable digital signature for Add-on" while connecting iVend Addon.
************** Internal to CitiXsys Support******************* Problem Statement Getting an error "Wrong executable digital signature for Add-on" while connecting iVend Addon Scenario Customer had one SAP Server(Enterprise) and 21 SAP clients. Over ...
Addon information was not updated for newly created store
Add-on Citixsys iVend Addon:Cannot start Add-on
Environment : iVend 6.6 With SAPB1 Problem Statement : When customer running SAP, get this error with the addon. “Add-on Citixsys iVend Addon:Cannot start Add-on” However, if SAP is ran with administration rights, the addon connects correctly. ...
Unable to Start iVend Add-on in SAP Business One
Environment: iVend Retail 6.6 7989 & SAP Business One 10.0 Problem statement: Unable to start iVend Add-on in SAP Business One Error:Access to the path 'C:\Program Files\SAP\SAP Business One\AddOns\CXS\CitiXsys iVend AddOn\CitiXsys Ivend AddOn.exe' ...
ISSUE WITH IVEND ADDON - HANA CLOUD
Environment : iVend 6.6 Patch 7915 Problem Description : ISSUE WITH iVend ADDON - HANA CLOUD Scenario : In the process of migrating iVend version 6.6 patch 7915 after installing the iVend add-on that comes in the patch 7915 folder but it is giving an ...
