Getting an error "Wrong executable digital signature for Add-on" while connecting iVend Addon.
************** Internal to CitiXsys Support*******************
Getting an error
Scenario
Customer had one SAP Server(Enterprise) and 21 SAP clients. Over the session, we removed the problematic iVend Add-on(Version 6.6) and installed the latest iVend Add-on(Version 6.6) at his SAP Server(Enterprise) and the Add-on connected successfully there, and it also installed successfully at one of his SAP client machines but while connecting the addon at his client machine an error was appearing "Wrong executable digital signature for Add-on ".
Solution No- 1
Go to the below path and look for the file "AddOnsLocalRegistration.sbo", take the backup of this file, and open this file in Notepad.
"C:\Program Files (x86)\SAP\SAP Business One" if you're running the 32 bits client
"C:\Program Files\SAP\SAP Business One" if you're running the 64 bits client
Note: Customers might be using more than one Add-on. So, first, we need to arrange the tags in the manner shown in the following image
Delete the highlighted portion ( below) from the tag and save the file. And try to connect the Add-on.
Solution No-2
iVend Addon Wrong digital signature of AddOn Citixsys AddOn uninstaller
Product Version 6.5 Update 6 integrated with Sap B1 Problem Statement At the time of registering the Addon in SAP its showing below message “ Wrong digital signature of AddOn Citixsys AddOn uninstaller” after upgrade. Proposed Solution Wrong digital ...
Unable to Start iVend Add-on in SAP Business One
Environment: iVend Retail 6.6 7989 & SAP Business One 10.0 Problem statement: Unable to start iVend Add-on in SAP Business One Error:Access to the path 'C:\Program Files\SAP\SAP Business One\AddOns\CXS\CitiXsys iVend AddOn\CitiXsys Ivend AddOn.exe' ...
Add-on Citixsys iVend Addon:Cannot start Add-on
Environment : iVend 6.6 With SAPB1 Problem Statement : When customer running SAP, get this error with the addon. “Add-on Citixsys iVend Addon:Cannot start Add-on” However, if SAP is ran with administration rights, the addon connects correctly. ...
Addon information was not updated for newly created store
GRPO Error in SAPB1 withour connecting iVend Addon
Environment : iVend 6.6 Cloud with SAPB1 cloud. Problem Statement : While making GRPO in SAPB1 , it displays the error message : (1) 2: This GRPO has items from PO Which were marked for Store Symptoms : While making GRPO in SAPB1 , it displays the ...
