ISSUE WITH IVEND ADDON - HANA CLOUD
iVend 6.6 Patch 7915
Problem Description :
ISSUE WITH iVend ADDON - HANA CLOUD
Scenario :
In the process of migrating iVend version 6.6 patch 7915 after installing the iVend add-on that comes in the patch 7915 folder but it is giving an error in SAP. The CXSINTEGRATION database was already created and user fields were created but still an error when starting the add-on.
1) We have checked the user profile at the system %Users% \AppData\Local\ .. and found that Citixsys Folder was not created.
2) We asked to run SAP with run as administrator then Citixsys folder was created and Add-on was connected.
Symptoms :
N/A.
We have checked and found that Citixsys Folder has not been created on the machine and inform client to run as administrator when starting SAP. again when client login into SAP the addon it was connected.
Addon information was not updated for newly created store
iVend Retail - Overview and Architecture
Overview and Architecture This article gives an overview of iVend Cloud. The article also discusses the different applications and modules of iVend Retail, brief description of these modules and finally overview of how the application suite is ...
How to download iVend addon for SAP 10 HANA
Query: - How to download iVend addon for SAP 10 HANA Answer: There is no separate addon for HANA, same addon can be used for both HANA and SQL. One can download the latest patch from below link and latest patch consist of latest iVend addon: - ...
iVend ADDON for SAP BUSSINES ONE - HANA and SQL
Version: 6.6, not version-specific Request: Customer requires Addon for iVend 6.6 with SAP HANA Resolution: Please download the latest patch 7915 from the CitiXsys Support portal (https://citixsys.service-now.com/) which contains the updated Addon ...
install add-on ivend for SAP B1 HANA and sync data between ivend and SAP B1
Environment: iVend 6.6 With SAP 10 HANA Problem Statement: User created fresh environment with IVend 6.6 Integrated with SAP version 10 With HANA 2.0.After installing ADD_ON encountered error message and failed to connect. Proposed solution: There ...
