iVend add on does not allow update List of Materials in SAP B1"Retail BOM can not be updated"
iVend Version 6.5 Update 6, iVend 6.6 with SAPB1 9.2
When a user is trying to update a List of Materials with the add-on iVend connected, It does not allow to update the BOM and displays this message: "Retail BOM can not be updated".
Not able to update the BOM throwing the error message.
User will not allow to update the Retail BOM in SAPB1 as it is integrated with iVend
Recommendations /Suggestion
It is always recommend to keep iVend addon running in SAPB1 . It is also suggested that don't make any changed in SAPB1-Retail BOM by stopping the iVend Addon. It may lead to data discrepancy in SAP B1 and iVend or integration failures related to Retail BOM.
SAP Business One - iVend Retail Integration Points
ISSUES WHEN INTIALIZING MASTER TABLES FROM SAP: "iVend 6.*.*.* add-on failed to update the database"
Error in Integration Monitor (SAP to iVend) in version 6.6 for event type "Customer"
*****************For Internal purpose********************* Product Version: iVend 6.6 Issue: Error in Integration Monitor (SAP to iVend) in version 6.6 for event type "Customer": Integration Error: System.Data.SqlClient.SqlException (0x80131904): ...
iVend Retail 6.5 Update 6 Patch 1
Recommendation(s) It is recommended that patch is applied in Test Environment first and then production environment. Preferable if replication and integration queue is all clear. Apply iVend Patch during business downtime Pre-Requisite(s) Back-up ERP ...
