Integration not working from SAP to iVend
Version:
iVend 6.5 Update 6 for this case (However not version specific).
Issue:
Integration events neither appeared in Integration monitor nor updating the corresponding records in iVend at HO. However, it is working fine from iVend Enterprise to SAP.
Cause:
Some part of Code in SBO_SP_TransactionNotification Stored procedure was commented.
Resolution:
We found that SBO_SP_TransactionNotification Stored procedure in SAP database had commented part which was causing the issue.
Once we un-commented that code issue got resolved and Integration from SAP to iVend also started moving.
Incident of the reference: INC0014024
Integration Error "System.Data.Odbc.OdbcException (0x80131937): ERROR [HY000] [SAP AG][LIBODBCHDB"
Environment: iVend 6.6 integrated with SAPB1 HANA Problem Statement: Integration was not working and its showing below message on Event Viewer Log “System.Data.Odbc.OdbcException (0x80131937): ERROR [HY000] [SAP AG][LIBODBCHDB DLL][HDBODBC] General ...
Integration stopped working between iVend and SAP
Product version: iVend 6.6 Problem Statement: A new implementation (iVend to SAP) integration suddenly stopped working. Symptoms: Integration was not working. Records are showing in the integration monitor with not processed status from iVend to SAP ...
Distribution Rule not working
Environment : iVend 6.5.6 Patch 2021_23 Problem Description : All the invoices and deliveries of 1 store are getting integrated to SAP without a Distribution rule. Solution: 1) Check the new distribution rule in the SAP and found that Distribution ...
Integration Monitor not working in SAP. Internal error (-1106) occurred [131-183]
Environment : iVend 6.6 with SAP B1 Problem Statement : Integration Monitor not working in SAP. Error Description :Internal error (-1106) occurred [131-183] Symptom: It is observed that the 'Database User' was missing the 'Select' privilege on ...
MEGA: Error Integration SAP to iVend - Items
****** For Internal Reference only****** Environment I-Vend 6.6 Patch 7747 Problem Description MEGA: Error Integration SAP to iVend - Items. Scenario Problems is with some products that can be created or updated in SAP, but in the integration monitor ...
