Integration Monitor not working in SAP. Internal error (-1106) occurred [131-183]
iVend 6.6 with SAP B1
Problem Statement :
Integration Monitor not working in SAP. Error Description :Internal error (-1106) occurred [131-183]
Symptom:
It is observed that the 'Database User' was missing the 'Select' privilege on "RepintegrationLog" table of CXSINTEGRATION database.
Resolution/Work Around :
After the Database user (e.g., B1_53424F44656D6F5553_RW) was granted sufficient privileges, the Integration monitor started working in SAP.
Recommendations /Suggestion : NA
Reference ticket: #15240
