Integration stopped working between iVend and SAP
A new implementation (iVend to SAP) integration suddenly stopped working.
Integration was not working. Records are showing in the integration monitor with not processed status from iVend to SAP and SAP to iVend.
Investigation/Observation:
It was observed that integration was working fine, but after some time due to SAP database corruption, customers renamed the SAP database name and then integration stopped working.
Root Cause:
User Error. SAP database (Which was already initialized and mapped with iVend database) name was changed.
Resolution/Workaround:
Support team helped to fix this issue.
Recommendation:
Strongly recommended to not rename the database name, especially in an already running and integrated environment. In case of DB corruption or a scenario like above, contact the support team for right guidance.
Reference ticket:
CS0010752
MEGA: Error Integration SAP to iVend - Items
****** For Internal Reference only****** Environment I-Vend 6.6 Patch 7747 Problem Description MEGA: Error Integration SAP to iVend - Items. Scenario Problems is with some products that can be created or updated in SAP, but in the integration monitor ...
SAP Business One - iVend Retail Integration Points
Error in Integration Monitor (SAP to iVend) in version 6.6 for event type "Customer"
*****************For Internal purpose********************* Product Version: iVend 6.6 Issue: Error in Integration Monitor (SAP to iVend) in version 6.6 for event type "Customer": Integration Error: System.Data.SqlClient.SqlException (0x80131904): ...
Integration Error "System.Data.Odbc.OdbcException (0x80131937): ERROR [HY000] [SAP AG][LIBODBCHDB"
Environment: iVend 6.6 integrated with SAPB1 HANA Problem Statement: Integration was not working and its showing below message on Event Viewer Log “System.Data.Odbc.OdbcException (0x80131937): ERROR [HY000] [SAP AG][LIBODBCHDB DLL][HDBODBC] General ...
