Integration Failed records (Customer type, update events) from SAP to iVend. Below is the error coming:
Check there may be Null values in CommentKey in iVend for any customer in the CusCustomerComment table.
Run SQL queries and correct the null values with 0 then re-trigger all failed records. Which in-return should sync into iVend.
