Integration Event not generating from iVend to SAPB1
6.5 Update 6 & 6.6 with SAP B1 10 SQL Server
Users created many objects in SAPB1 such as customers, products etc but it didn't generate the integration events towards iVend.
Steps if any
Resolution
Check database user and  database user (or technical user) must be sysadmin
This concludes the KB on iVend POS –  The notification in not generating any event and customer is using SAP 10.0 with SQL
    • Error in Integration Monitor (SAP to iVend) in version 6.6 for event type "Customer"
      *****************For Internal purpose********************* Product Version: iVend 6.6 Issue: Error in Integration Monitor (SAP to iVend) in version 6.6 for event type "Customer": Integration Error: System.Data.SqlClient.SqlException (0x80131904): ...
    • Integration Error "System.Data.Odbc.OdbcException (0x80131937): ERROR [HY000] [SAP AG][LIBODBCHDB"
      Environment: iVend 6.6 integrated with SAPB1 HANA Problem Statement: Integration was not working and its showing below message on Event Viewer Log “System.Data.Odbc.OdbcException (0x80131937): ERROR [HY000] [SAP AG][LIBODBCHDB DLL][HDBODBC] General ...
    • Events are not generating from SAP B1 To iVend
      Environment: iVend 6.6 integrated with SAPB1 Problem Statement: Events are not generating in Integration Monitor from SAP To iVend. Symptoms: NA Resolution/Work Around: Follow below steps and check if “Enable Transaction Notification” is enable. 1: ...
