Events are not generating from SAP B1 To iVend
Environment: iVend 6.6 integrated with SAPB1
Problem Statement: Events are not generating in Integration Monitor from SAP To iVend.
Symptoms: NA
Resolution/Work Around: Follow below steps and check if “Enable Transaction Notification” is enable.
1: Login in SAP Business One.
2: Go To: Administration >> System Initialization >> Open General Settings >> Click on Services Tab.
3: On Services Tab make sure “Enable Transaction Notification” setting is ON, if not then enable this setting click on Update button and then create transaction or update any master and check integration monitor. Check below screenshot from General Settings “Services Tab”
Recommendations /Suggestion: NA
