In Co-mingle mode Handheld device to configure store wise
How to configure a handheld device to only one store and store-wise transactions will be available to process instead of all.
Proposed solution/workaround:
If iVend environment in Co-mingle mode then handheld cannot be setup store-wise. As API services are installed at Enterprise, handheld will attach to HO only.
Environment: iVend 6.6 Problem statement: How to configure a Handheld device to only one store and store-wise transactions will be available to process instead of all. Proposed solution/workaround: If iVend environment in Co-mingle mode then handheld ...
'Customer Field' in Item Lookup in handheld Device
‘Customer Field’ in Item Lookup in handheld Device The Item Lookup option is used for searching the available quantity of the item in a store. The purpose of this field "Customer" on Item lookup screen in the Handheld app, is to display the ...
Stock Management with Handheld Devices
Stock Management with Handheld Devices The iVend Handheld module in iVend Retail versions 6.2 and above allows its users to manage store inventory using a iVend Handheld device running on Android Mobile OS version 5.x and onwards. The application is ...
Configuring iVend handheld on an Android phones.
Follow the below-detailed steps of configuring iVend handheld on an Android device. Step 1. Download and install the iVend handheld from Android Play Store. Step 2. Once the application is installed tap on Open button to open the iVend handheld ...
Change from Mixed Mode to Separate Store
------------------This article is for only internal use ------------------------ Product version: iVend 6.6 with SAPB1. Problem statement: A Store was created in mixed mode however it was required to be created as Separate Mode Store Proposed ...
