Import format for Inventory counts with expiration dates
Product Query
Is there any format to import for inventory Counts so we can import expiration date also for batch items ?
Answer
We can just save the current batch number in this case since the inventory counting document is solely utilized for auditing purposes. The expiration date has to be preserved at the moment of good receipt, when the batch number is generated.
As of now, the user must manually enter the expiration date because there is no such option to enter the same incase of Inventory Counting.
Consolidating Stock Take Counts
Consolidating Stock Take Counts (Done by multiple users happening at different Locations) iVend 6.5 introduced a new feature where the stock take count can be done with multiple users for the same or different locations at a time and thereafter all ...
Require to make the inventory as Zero for particular store
Inventory Counting Manual CountingAndFile Upload
Inventory Counting - Manual and File Upload In versions of iVend Retail 6.5 and above, the system allows users to perform physical stock counts of inventory products. It also enables the user to reconcile the system inventory against the actual ...
Quotation Expiration
Quotation Expiration This feature is incorporated in iVend Retail, to determine the duration for which the created "Quotation" will hold Valid. Option to enable manager override to convert expired quotations to sales or order is also present. This ...
Good Receipt Format for Import Batch item with batch expiry date.
Product version: iVend 6.5 update 6 Problem Statement: Customers need to import Batch Managed item on Store MC-->Goods Receipt screen, with batch expiry date. Proposed Solution: Suggested to import the data in the following format using the delimiter ...
