iMatrix Item Import tool problem
IMatrix Version 5.9.6.0 Update 10
Problem Description :
Scenario :
While Uploading the file all details are correct, but they are incorrect order.
1) First Define the order from the Define the order from define attribute from the global settings.
2)Once the desired order is defined then check the global settings before uploading the file.
3) Consider the below order which is correct one In order we have defined First 4 Characters for Design, then W,3 Characters for Product etc. and so on.
4) In case you need to delete any of the parent or child items then user defined attributes should be opened.
Symptoms :
Character 'W' has been defined after style but when uploaded showing in incorrect order.
Once enable the global settings before upload product can be easily uploaded in order which has been defined and after enabling the user defined attribute Child and parent items can be deleted from item matrix.
ADD-ON IMATRIX 5.9.4.0 compatibility with iVend 6.6
Environment: iVend 6.5.6 Patch 2021_23 Problem Description: Inquiry about iMatrix version compatibility. Scenario: Client is about to migrate from the iVend version from 6.5.6 to 6.6 and asking that any change will happen in the iMatrix add-on ...
Good Receipt Format for Import Batch item with batch expiry date.
Product version: iVend 6.5 update 6 Problem Statement: Customers need to import Batch Managed item on Store MC-->Goods Receipt screen, with batch expiry date. Proposed Solution: Suggested to import the data in the following format using the delimiter ...
Unable to Validate Item Matrix template
Introduction: This article will demonstrate how to resolve the issue of upload templates of Item Matrix in SAP by using the initialization tool, where maybe we can face the below error. Case Study: The below example is a case study where we are ...
Unable to Import Bonus Buys Template on MC Error : Transaction/sale item/payments sheet not found
Product version: 6.5 update 6 Problem Statement: Unable to Import Bonus Buys Template on MC Error: Transaction/sale item/payments sheet not found in uploaded file. Proposed Solution/Workaround: Check the format of the required sheet. Export and ...
Updating problem in Importing Loyalty Customer Excel.
Environment: 6.6 Short Description: Updating problem in Importing Loyalty Customer Excel. Product Query: The data for BirthDate and LoyaltyCustomerCountries is not updated in iVend during the import procedure Resolution/Work Around: For BirthDate, ...
