ADD-ON IMATRIX 5.9.4.0 compatibility with iVend 6.6
iVend 6.5.6 Patch 2021_23
Problem Description:
Inquiry about iMatrix version compatibility.
Scenario:
Client is about to migrate from the iVend version from 6.5.6 to 6.6 and asking that any change will happen in the iMatrix add-on regarding the version change.
  1. Check the current version of I Vend (In this case 6.5.6 )
  2. Check the current version of item matrix (5.9.4.0 )
  3. Item matrix add on version 5.9.4.0 is compatible with iVend 6.6 also
N/A
Item matrix add-on version 5.9.4.0 is compatible with iVend 6.6.
    • iVend Handheld Compatibility Specification
      Environment: iVend 6.6 Patch 8024 Problem Description: iVend Handheld Compatibility Device specification. Scenario: iVend Handheld device specification and OS compatibility. iVend Handheld for Android recommended (compatible) device make/model ...
      Environment: iVend 6.6 Problem statement: iVend Handheld Compatibility Device specification. Scenario: iVend Handheld device specification and OS compatibility. iVend Handheld for Android recommended (compatible) device make/model Version of Android ...
    • Is iVend 6.6 compatibility with SQL Server 2019?
      Version: 6.6 Query: Is iVend 6.6 compatibility with SQL Server 2019? Answer: Yes, the below latest version of SQL is compatible with iVend 6.6 Miicrosoft® SQL Server 2019 - 64 Bit (x64) - Express, Standard, Enterprise Edition Note: Also find attached ...
    • SAGE ERP X3 Patch Compatibility
      Customer want iVend Connector (Jan 2023) Compatible with Sage ERP X3 Patch 30 Environment: 6.6:7989: Sage ERP X3 Short Description: SAGE ERP X3 Patch Compatibility Product Query: Is iVend Connector(Jan 2023) compatible with Sage ERP X3 Patch 30? ...
