customer is experiencing an issue with stock transfer requests. "Product with code 0 does not exist"
iVend 6.6 7989 with SAP B1 9.3
When they try to create a stock transfer request, users receive an error message-
"Product with code 0 does not exist."
Users receives an error message that says "Product with code 0 does not exist" when they try to create a stock transfer request.
The stock transfer request does not create.
Cause:
The error is caused by the import adding the product XXXXXXXXX for each line that contains 0. The product with code 0 does not exist, so this causes the error.
Workaround:
The workaround is to not enter non-existent products into the import file.
Proposed Solution/Workaround:
Do not to enter non-existent products into the import file.
The import should be updated to omit any lines that contain 0. This would prevent the error from occurring.
iVend Stock transfer Code field appear blank
Product Version: 6.6 integrated with Sap B1 Problem Statement: Customer generated stock transfer from General warehouse to retail warehouse on SAP however at the time of receiving stock transfer on store code field appears blank. Proposed Solution: ...
Stock Transfer Transactions with an ERP
Stock Transfer Transactions with an ERP (SBO in the Backend) In this article we talk about 4 important transactions in iVend Retail. This article describes i. (i) Stock Transfer Request ii. (ii) Stock Transfer Request Received iii. (iii) Stock ...
iVend Stock Transfer request issue Cannot save stocktranferRequest.StocktransferRequest not valid
Product version: 6.6 Problem statement - INC0017137 iVend Stock Transfer request issue Cannot save stock transfer Request. Stock transfer Request not valid. Error-Code/Id cannot be left blank Proposed solution: - This issue can be resolved by sql ...
UPC Code
UPC Codes What is a Universal Product Code (UPC)? Simply put, a UPC, short for universal product code, is a type of barcode printed on retail product packaging to aid in item identification of a particular item. It is most widely and commonly used in ...
Subsidiaries issue: Not able to recieve the Stock Transfer
iVend version: 6.6; Patch 7499 Issue: Customer configured two subsidiaries. Both the subsidiaries are having separate INTRANSIT warehouse, one for each subsidiary. When a Stock Transfer is raised and receiving warehouse is from another subsidiary, ...
