Enable Signature capture prompting in iVend
iVend 6.6 8567
Enable it from the Payment Type option in Management console option
Management Console>>Administration>>Finanacial>>Payment Type>>
select the Payment Type in which you want to add and mark on "Required Signature" option.
Topaz Signature Pad Model T-S460-HSB-R
Introduction Topaz Signature Pad Model T-S460-HSB-R is added to the iVend Retail supported hardware list. This signature pad is a pressure-sensitive electronic signature pad with stylus. This signature pad shows the signature on the computer screen. ...
Topaz device Signature Skip
Environment : 6.6 with 7825 with SAP B1 9.3 and Electronic signature devices.Topaz device Model-T-S460-HSB-R Symptoms: POS user was able to do Sale without Signature of Customer however Signature parameter was configured on Payment Type. Problem ...
Print button not enable in PO & GRPO
Problem statement Print button not enable on PO Environment iVend Retai 6.6 7989 & SAP Business One 10.0 Symptoms After creating the purchase order in iVend Management Console Print button bottom right not enable. Resolution/Work Around Check below ...
Enable the Print button on Inventory Counting
Environment: iVend 6.6 Problem statement: Enable the Print button on Inventory Counting Resolution/Work Around: 1: Login in MC. 2: Click on Administration Tab >> Retail Configuration >> Document Print Profile. 3: Select Document Print Profile and ...
