Print button not enable in PO & GRPO
Problem statement
Print button not enable on PO
iVend Retai 6.6 7989 & SAP Business One 10.0
After creating the purchase order in iVend Management Console Print button bottom right not enable.
Check below resolution Steps along with screenshot.
1: Open iVend Management Console at store
Go To: Administration >> Retail Configuration >> Document Print Profile. Click on New Button.
#: Configure the Document Print Profile for the requested document, check below.
2: Open requested document and check this time print button should enable. If not, then restart management Console and check.
Recommendations /Suggestion
 Above suggestion can be tried on iVend 6.6 any patch with and without SAP B1 9.3 also.
