User based discount for Product Master
1: Open Product Master and configure "Max Discount Percentage [Manual]"
2: Created two Security Rolls, as mention highlighted below.
Security Rolls
User A: Attached
Security Role Admin2
This User has full rights in security Rolls.
User B: Attached Security Role Admin3
From the User B we removed to below highlighted rights
Retail Profile
Configure "Max Sale Discount Percent Allowed"
Error while creating a new product group with Business Central
How to hide Discount Field over customer master screen for specific user
Problem Statement \scenario: While creating customer from POS, POS user mentioned 80% or 50% discount after which item was scanned and discount was applied as defined for the customer. Resolution : Below are the steps user require to follow-up for ...
Integrate : Item Master Properties from SAPB1 Product master to iVend Product Master
Environment : iVend 6.6 with SAPB1 9.2 Problem statement /Query : Integrate Item Master Properties from SAPB1 Product master to iVend Product Master Symptoms : User can define the item properties in SAPB1 Product Master screen and requires them in ...
Discount Resolution Setup
Discount Resolution Setup The Discount Resolution Setup grouping feature helps in determining how the discounts will be calculated on an item in the event that multiple discounts are applied in a single transaction. The discounts have been ...
A/R Invoice see different discount between iVend and SAP B1
Problem Reported : Customer notified to us about different A/R Invoices between iVend and SAP. they realize that they have a difference in the discount between SAP and iVend, it is showing discount negative and decimal less than one. Cause : ivend ...
