Integrate : Item Master Properties from SAPB1 Product master to iVend Product Master
iVend 6.6 with SAPB1 9.2
Problem statement /Query :
Integrate Item Master Properties from SAPB1 Product master to iVend Product Master
Symptoms :
User can define the item properties in SAPB1 Product Master screen and requires them in iVend Product Master.
iVend Integration doesn't integrate Item properties from SAPB1 to iVend.
Remove Customer Master which has transaction and also remove those customer which has no transaction
Environment: Ivend 6.6 Problem statement: Need to Remove Customer Master which has transaction and also need to remove those customers which has no transaction details. Resolution/Work Around: 1. Remove customer master which has no transaction ...
iVend Retail - Quick data entry form to enter Product Master data
iVend Retail - Quick data entry form to enter Product Master data (Product List) In earlier version of iVend there were only two (2) ways by which Products could be entered in to the iVend system and these were: 1. Import / Export 2. Product Master ...
Error while creating a new product group with Business Central
iVend POS - Master-Detail Report
Master-Detail Report This article discusses the basic steps for creating a Master - Detail report. 1. First, create a relation between data sources. If the relation will not be created and/or the relation properties of the Detail data source cannot ...
