UpgradeError:27506 Script Upgrade Dataupated Auto 6.6 Sql Line 1171 statement has been terminated
This KM is for Internal Purpose Only for CitiXsys
Environment : iVend 6.5.6 database restored with iVend 6.6 Installer
Problem Statement : While upgrading from 6.5.6 to 6.6 when run the iVend installer, get the error validation message ‘Error 27506 Executing SQL Script Upgrade Dataupdates Auto 6.6 Sql Line 1171 The statement has been terminated’
Symptoms : Environment Specific
Resolution/Work Around : We have suggested below steps to perform and issue has been resolved.
Step 1. Please restore the database again from the backup.
Step 2. Please execute below query once database successfully restored :
Step 3. update CfgReport set IsCustomized-0 where ReportKey='1'
Step 4. Please verify whether above query successfully executed.
Step 5. Now run the iVend installer.
Recommendations /Suggestion : N/A
    • Upgrade iVend version from 6.5 to 6.6
      Environment: 6.5.X Statement : Is there any guide to show how to upgrade the iVend version from 6.5 to 6.6, step by step? Resolution: iVend 6.6 is a quantum jump with various new technologies such as Quartz, Signal R, GZip MS IIS, SQL Servers, etc. ...
    • compatibility version SAP & SQL Version
      Product Query Customer currently using the SQL version 2016 in HO and stores in 2008 express . SQL 2019 and higher version will support ivend 6.6? SAP Version 10 and Pl 2405 and higher PL version will compatible with ivend integration ? Answer As per ...
    • Unable to open the ivend configuration after upgrade
      Product version: iVend Retail Configuration Manager 6.5 update 6 Problem statement: Customer not able to open the iVend configuration manager and Integration stops after upgrade. Proposed solution: We checked Windows event viewer --> System or ...
    • iVend 6.6 Performance Issues-Required SQL Index
      This KM is for Internal Purpose Only for CitiXsys Environment: iVend 6.6 Problem Statement: We have noticed that customers are facing performance issues with iVend 6.6. Symptoms: Environment Specific Resolution/Work Around: Technical Team has checked ...
    • iVend Upgrade - Best Practices Overview
      Purpose The purpose of this article is to introduce the CitiXsys iVend Partner community to an overview of the recommended steps to be followed while upgrading the iVend Retail applications in accordance with best practices. Best Practices The ...
