compatibility version SAP & SQL Version
Product Query
Customer currently using the SQL version 2016 in HO and stores in 2008 express .
SQL 2019 and higher version will support ivend 6.6?
SAP Version 10 and Pl 2405 and higher PL version will compatible with ivend integration ?
Answer
As per the requirement, the recommended versions of SAP and SQL are as follows:
  1. MS SQL 2019
  2. SAP Business One 10.0 (Latest PL)
And find below
For further specifications, please refer to the attached document for more details.
