Unable to Send Order to Kitchen.
Unable to Send Order to kitchen.
Error:
After scanning the product when clicking on the Send Order button the system gives the error.
Login in Management Console.
1: Go To Operation Tab: Inventory >>> Product.
2: Search the product and click on Edit Button.
3: Scroll down product master window there is a User Defined field “Is Print Kitchen Disabled”
If you want to Send the Order to the kitchen this field “Is Print Kitchen Disabled” should be unchecked.
    • Unable to Send Order to the Kitchen
      Problem Statement: Unable to Send Order to kitchen. Error: After scanning the product when click on the Send Order button system gives the below error. Solution: Login in Management Console. 1: Go To Operation Tab: Inventory >>> Product. 2: Search ...
    • iVend 6.6 Hospitality Order cannot be completed, Send the Order to Kitchen
      Environment: iVend 6.6 Hospitality Symptoms: Customer was not to complete order. Problem statement: When customer click on Credit Tender on iVend POS while updating Order in Dine, it displayed the error "Order cannot be completed, Send the Order to ...
    • Unable to Suspend a Quotation
      Environment: 6.6 Short Description: Unable to Suspend a Quotation. Product Query:  When a customer attempts to suspend a quotation, they receive the error "Current transaction cannot be suspended." Resolution: iVend system does not currently support ...
    • Store Replication Error The underlying connection was closed An unexpected error occurance on a send
      Product version: iVend 6.6 integrated with SAPB1 Problem statement: While updating the Store Replication Service, it displayed the error message- "The underlying connection was closed An unexpected error occurance on a send" Proposed ...
    • Unable to deactivate Master till
      Product version: iVend 6.6 Problem statement: Unable to deactivate Master till from master till setup. Symptom: Clicking on the Active check box ( as marked above) does not changes the the status. Cause: In above situation , the master till which is ...
