Store Replication Error The underlying connection was closed An unexpected error occurance on a send
iVend 6.6 integrated with SAPB1
While updating the Store Replication Service, it displayed the error message-
"The underlying connection was closed An unexpected error occurance on a send"
Proposed Solution/Workaround:
New iVend configuration Manager exe can be deployed on Store Machines.
Steps of deployment :
1. Close the iVend Configuration Manager and exist from Task bar
2. Download the file
3. Take a backup of ConfigurationManager folder from below given path
C:\Program Files (x86)\CitiXsys\iVend Retail\ConfigurationManager
Replication stuck and Not Moving
Problem: Replication not moving from HO to Specific Store. Symptoms: Replication Log File Not generated and Event Viewer is showing "INVALID CLASS ERROR" What need to be Check : 1. Right Click on My PC 2. Click on Manage 3. Now Go to Services and ...
Replication not working
Environment: iVend 6.6 Problem Statement: Replication service not working due to controller application Error Screenshot: Solution: - This issue happened due to there’s an error showing from controller application when customer removed this ...
Replication not working at store(s) (TLS 1.2)
Environment: 6.6 Problem statement: Replication not working at store(s). Symptoms: It was observed that at iVend Enterprise/Store where the "iVend Cloud Security Enhancements"(TLS 1.2) enabled, does not have the compatible TLS 1.2 replication ...
Addon information was not updated for newly created store
Unable to Start iVend Add-on in SAP Business One
Environment: iVend Retail 6.6 7989 & SAP Business One 10.0 Problem statement: Unable to start iVend Add-on in SAP Business One Error:Access to the path 'C:\Program Files\SAP\SAP Business One\AddOns\CXS\CitiXsys iVend AddOn\CitiXsys Ivend AddOn.exe' ...
