Replication not working
Replication service not working due to controller application
Error Screenshot:
Solution: -
This issue happened due to there’s an error showing from controller application when customer removed this controller application and deleted its files and also we have reconfigured IIS default website, iVendReplication and ASP.NET after all of these activities the issue resolved and replication service is working fine now.
    • Replication not working
      Environment: iVend 6.6 Problem Statement: Replication service not working due to controller application Solution: This issue happened due to there’s an error showing from controller application when customer removed this controller application and ...
    • iVend Replication not working from Store to Enterprise
      Product version: 6.5 Update6 Problem statement : Replication was not working from Store to Enterprise Proposed solution: In this case we require to check replication log file on below path C:\Program Files (x86)\CitiXsys\iVend Retail\Replication and ...
    • Replication not working at store(s) (TLS 1.2)
      Environment:  6.6 Problem statement:  Replication not working at store(s). Symptoms: It was observed that at iVend Enterprise/Store where the "iVend Cloud Security Enhancements"(TLS 1.2) enabled, does not have the compatible TLS 1.2 replication ...
    • SALES REPLICATION ERROR
      Environment: IVend 6.6 with SAP B1 Problem statement: After Applying patch 7723 for version 6.6 sales are not replicating. Did the test by modifying an article and after replicating but the sales did not. Below troubleshooting steps followed: 1.- ...
    • Replication Monitor Error: 'System.OutOfMemoryException' was thrown
      Replication Monitor Error: 'System.OutOfMemoryException' was thrown. Environment : iVend 6.6 Problem Statement : Replication monitor error in Store ."Exception of type 'System.OutOfMemoryException' was thrown." Proposed Solution/Workaround : The ...
