Store Initialization Error [Microsoft][ODBC SQL Driver][String data, right truncation
Problem statement :
Below error appeared while Initializing the store
iVend version :
6.6 8929
This problem generally occurs when Configuration manager version and patch not updated
Resolution / work around :
Make sure the configuration manager should be updated.Check below path and image
Path:C:\Program Files (x86)\CitiXsys\iVend Retail\iVendReplicationEngine\bin
NOTE: The above image is for reference only; the patch version may vary.
