Server Error in '/iVendReplication' Application.Input string was not in a correct format on
Replication is not working on Store
Error :
Server Error in '/iVendReplication' Application.Input string was not in a correct format.
Version
ivend 6.6
Recommendation:
Please check the web config file on Store and check
Below tag value should be available
<add key="SiteId" value="2"/>
<add key="ServerSiteId" value="1"/>
<add key="ServerAddress" value="http://...../iVendReplication/iVend/Hubs"/>
