While registering customized addon iVend Enterprise MC, there are below fields :
The feature enables the administrator to register the new Add-On for iVend. Using Add-On iVend functionality can be extended.The feature for managing iVend Add-On is available on the iVend Enterprise.
Administrator > IT Administration > Addon Manager.
Below are few buttons and their description, present on the addon manager screen:
Add-On Name -
Displays the Add-On name. The name is provided as while the Add-On is developed for iVend.
Add-On Version
Displays the Current Version of the registered Add-On in the system.
Description
Enter the Description of Add-On for easy identification.
Add-On File Path
Select the path of iVend Add-On files.
Connect/Disconnect Add-On
Shows whether the Add-on is connected or not.
Is Mandatory
Shows whether Add-on is mandatory or not
Setting Type
Displays the Add-On Setting type. i.e. Store
Setting Name
Displays the Store name
