Problem with updates on MC 2020_7835 Patch
iVend Version 6.6 7835
Customer is trying to apply patch iVend 6.6 7835 but unable to update.
Configuration Issue
Customer has resolved this issue with patch updation. Now all patches deployed successfully on HO and application is working fine.
Recommendations/Suggestion:
Patch deployment document can be received from support team and suggested to follow all the steps.
    • 6.6 iVend Retail - Patch Deployment Process
      Query: How to plan iVend 6.6 upgrade and Patch update? Solution: Please follow the attached "iVend 6.6 Patch deployment Process" document. Additional Information: Patch deployment process document is available in Download section of iVend retail. In ...
    • Microsoft Azure is available in ivend if yes in which patch level or version
      Product version: iVend 6.6 Problem statement: Kindly update us about single sign on for Microsoft Azure is available in ivend if yes in which patch level or version ?? Proposed solution/workaround: SSO is not feasible through custom development in ...
    • Error After Applying Patch
      Problem Statement Customer is trying to apply PATCH 7648, in the HO server, all patches deployed successfully. When replicating to a store and MC starts, the system showing an error message 'Patch1 Database 2020 7648 Failed'. Environment iVend ...
    • Patch failed to apply 7648
      Product version: iVend 6.6 Problem statement: Customer is trying to apply Patch 7648, in the HO server, all patches deployed successfully. When replicating to a store and MC starts, the system showing an error message Database 2021_7825 Failed'. ...
