Patch failed to apply 7648
Customer is trying to apply Patch 7648, in the HO server, all patches deployed successfully. When replicating to a store and MC starts, the system showing an error message Database 2021_7825 Failed'.
Proposed Solution/Workaround:
We follow the below step:
1.We suggest to restart the SQL services and try again.
2.HO Management Console has been applied successfully for Management console patch.
3.It try to load the Database patch but it again fail.
4.We apply the patch manually.
    • Error After Applying Patch
      Problem Statement Customer is trying to apply PATCH 7648, in the HO server, all patches deployed successfully. When replicating to a store and MC starts, the system showing an error message 'Patch1 Database 2020 7648 Failed'. Environment iVend ...
    • 6.6 iVend Retail - Patch Deployment Process
      Query: How to plan iVend 6.6 upgrade and Patch update? Solution: Please follow the attached "iVend 6.6 Patch deployment Process" document. Additional Information: Patch deployment process document is available in Download section of iVend retail. In ...
    • iVend Retail 6.5 Update 6 Patch 1
      Recommendation(s) It is recommended that patch is applied in Test Environment first and then production environment. Preferable if replication and integration queue is all clear. Apply iVend Patch during business downtime Pre-Requisite(s) Back-up ERP ...
    • Error "Inventory Status updated from enterprise server failed" while using Retrieve from Server
      *******Internal to CitiXsys******* Environment:  iVend 6.6 patch 7574 with SAP B1 9.3 Problem Statement: Getting an error while using Retrieve from Server functionality at Store Server. Whenever trying to view item inventory at Store Management ...
    • Microsoft Azure is available in ivend if yes in which patch level or version
      Product version: iVend 6.6 Problem statement: Kindly update us about single sign on for Microsoft Azure is available in ivend if yes in which patch level or version ?? Proposed solution/workaround: SSO is not feasible through custom development in ...
