Old transactions are not showing on Inventory Audit Report
Product Version:
6.5 Update 6
Customers have reinstalled POS and Management console for store, created backup of store database from enterprise management console, restored it in store database, POS and Management console are working properly but old transactions are not showing on Inventory Audit Report.
Customer was not provided the desired date in Transaction CutOff Date at the time of DatabaseBackup on Enterprise MC for Store.
 By default, the current date means it will not take transactional data before today's date. So customer need to give desired
Steps if any:
Constraints / Scenarios:
    • Inventory Audit report showing Blank After Store Re-initialization
      Problem Statement Inventory Audit report showing Blank After Store Re-initialization Investigation Upon reviewing the issue, it was found that the inventory log data was missing in the respective SQL table. After further inspection, we identified ...
    • Inventory Audit report after Store Re-initialization
      Environment: iVend 6.6 with SAP B1 Query: The customer is creating the inventory audit report after re-initializing of store, they are extracting the data from the ‘InvInventoryItemLog’ table but the data is not available in the mentioned table. ...
    • iVend Inventory Audit Report display Error "Incorrect Syntax near 'order'
      Environment: iVend 6.6 Problem Statement: Inventory Audit was not working on Enterprise Management Console Its shows error message “Incorrect Syntax near 'order' Incorrect Syntax near the Keyword 'As' Statement(s) could not be prepared". Proposed ...
    • Void Sales report isn't showing any result.
      Problem Statement Void Sales report isn't showing any result. Cause Void sales logging might not be enabled in the Retail Profile that is being used. Solution Please open retail profile and look for checkbox "Log Voided Transaction". If this option ...
    • iVend Retail Audit Log
      iVend Retail Audit Log The Audit log is one of the most important features that comes with iVend versions 6.5 and above. It allows for the tracking of all users’ data changes in the application. All operations such as Add, Update, and Soft Deletes ...
