Loyalty uncheck for Store Cash Customers
iVend 6.6 7989 with SAPB1.
Is it possible to Loyalty uncheck for Store Cash Customers
Workaround/Resolution:
Once the customer is created in iVend and its loyalty card is attached to a customer.
Customers cannot be made non-loyalty customers. User can mark the customer inactive in iVend Loyalty Card Screen so Customer will be inactive from both screens i.e. Customer Screen & Loyalty Card Screen and POS cashier will not be able to use these customers.
In Loyalty Plan Details User can specify (exclude) the Customers or Customer Groups and manage that way who can or cannot get the points
Reference ID:
CS0009644
    • Loyalty uncheck for Store Cash Customers
      Environment: iVend 6.6 7989 with SAPB1. Problem Statement: Is it possible to Loyalty uncheck for Store Cash Customers Workaround/Resolution: Once the customer is created in iVend and its loyalty card is attached to a customer. Customers cannot be ...
    • Multiple SMS for single Loyalty Transactions
      Environment : iVend Version 6.6 with SAPB1 9.2 Problem Statement: Multiple SMS for single Loyalty Transactions Symptoms : Multiple SMS for single Loyalty Transactions Resolution/Work Around : Due to SMS gateway ,not returning the success message, the ...
    • Loyalty customers
      iVend Version: 6.5 Update 6 Patch 2 Problem Statement: After setting up loyalty Program user creates loyalty customer encounters an error message cannot select Loyalty Program. Proposed Solution: For the issue to get resolved need to check the box is ...
    • Loyalty - Award and Redeem Points
      Loyalty – Award and Redeem Loyalty Points at the POS iVend Retail includes a fully featured Customer Loyalty program. iVend Loyalty is a points and rewards application designed to enhance the opportunities to win and retain new customers and greatly ...
