Loyalty customers
Loyalty customers
iVend Version:
6.5 Update 6 Patch 2
After setting up loyalty Program user creates loyalty customer encounters an error message cannot select Loyalty Program.
For the issue to get resolved need to check the box is Loyalty member and select the loyalty Program from drop down.
Steps:
For choosing customer as Loyalty customer
1. On management console chose Operations >> Business Partner >> Customer.
2. Chose the Desire Customer check the box is Loyalty member.
3. Select Loyalty Program from the drop Down.
4. The issue will get resolved.
Constraints/Notes –: NA
