iVend -Sage Expense Journals - Intergration Events
 iVend 6.6 with Sage
Problem statement
The Expense Journals generated in iVend and replicated to X3 needs to be extracted on a report, but also the expense journals must be switched off. Can this be done and implemented?
1) Go to iVend Enterprise --> Registered application--> Disable the Expense
2)  There is iVend table for  till variances, which can be used to make report for Expense Entries
select TillVarianceKey, TillVarianceDetailKey,* from TilVarianceDetail
Recommendations /Suggestion
It is suggested to configure First on TEST System before doing on PRODUCTION System
    • Expense Journal Created in X3 at time of Day End of Tills can we have these entries checked where do
      ******* Internal********* KB is for a very initial level of information / details that can be used to Relate and check mapping of Expense Journal account in Sage X3 against the till variance account in iVend Incident: INC0041428 Environment: iVend ...
    • Unable to see and update stock transfer records in integration log from iVend to Sage X3
      Environment iVend Version 6.6 7648(Sage X3) Problem Statement We are not able to transfer stock from iVend to Sage X3, rather the transactions move from the Senders Site in iVend to a GIT site in iVend and remain there Symptoms Configuration Issue ...
    • iVend Replication Events Generate Steps
      Internal to Citixsys Support Team Environment: iVend 6.6 Problem Statement: In some cases we require to generate replication events like product add/update events to match the product data between Enterprise and store. Symptoms: N/A Resolution/Work ...
    • Object List Where Events Are Exposed
      Introduction This knowledge base article contains a list of the iVend Retail Objects where their Events are exposed in the iVend Management Console and the iVend Retail Point of Sale. Environment: iVend Version 6.5 Overview This brief article ...
    • iVend Retail for Sage 300 Released
      Introduction This article pertains to the release of the Integration between iVend Retail and Sage 300, which has been developed using iVend Extensibility and the Sage 300 APIs. With this release Sage 300 retailers can now achieve their omnichannel ...
