iVend configuration manager is not opening
When trying to open the iVend configuration manager it is not opening , because of this replication is not working .
Suggest to please restart the problematic store machine
Configuration manager issue, showing the error "hexadecimal value 0x00, is an invalid character"
Version 6.5 Update 6 Issue Configuration manager issue, where it was not opening and showing the error "'.', hexadecimal value 0x00, is an invalid character. Line 8, position 1.", below is the error message from the CitiXsys - CXS RetailLog.xml file: ...
Upgrade iVend version from 6.5 to 6.6
Environment: 6.5.X Statement : Is there any guide to show how to upgrade the iVend version from 6.5 to 6.6, step by step? Resolution: iVend 6.6 is a quantum jump with various new technologies such as Quartz, Signal R, GZip MS IIS, SQL Servers, etc. ...
iVend Configuration Manager
Environment : iVend 6.6 Problem Statement : The "Require manager approval" button on the POS User menu screen either disabled or removed from the current position. This is because users often tend to click on this button unintentionally when they ...
Manager Override
Manager Overrides Overview While carrying out normal day-to-day transactions at the POS terminal, there are many situations where an intervention from the Manager could be required to complete the transaction. Deciding on what particular actions ...
Error occurred while opening iVend Pos Application
Problem statement Error occurred while opening iVend Pos Application Environment iVend 6.6 Symptoms While try to open iVend Pos Application in Test Machine below error message shown: An error has occurred in the application all errors have been ...
