Item and Item price is not integrating from Sagex3 to iVend
When trying to update item description and item price from Sagex3, it is not updating to iVend Ho Database.
Reason/Cause:
This problem occurred due to RetailInitialization.xml file got corrupted under iVendSageX3Connector configuration folder
Regenerate RetailInitialization.xml file under iVendSageX3Connector configuration folder.
After making the above mentioned changes the item description and prices are integrating successfully from sage x3 to iVend Ho Database.
None
    • Item cost price do not find in price list over iVend
      Product version: iVend 6.6 with SAPB1 9.3 Problem statement: Item cost price do not find in price list in iVend. Symptoms: Item cost price do not find in price list over iVend. Proposed Solution/Workaround: In Price list retail price list should be ...
    • Item Price in ERP and iVend same but POS shows different price
      Problem Statement: User creating a sale with an item and the price of the product was 0.20. The price was changing on the pos screen while selecting the batch detail. After selection, the batch details the price getting change from 0.20 to 40.00. ...
    • Item price is not showing correctly at Ivend POS Terminal
      This article will demonstrate one of the configurations of Product which may lead to showing unexpected Total value of Product at POS terminal. Case Study : The below example is a case study where the price defined in SAP was 98. The same price was ...
    • No Price showing while Printing item Labels iVend
      Environment iVend Retail 6.6 integrated with SAP B1 Problem Statement At the time of print Label price was showing zero. Symptoms: After update the price through pricelist from SAP its was updating on Price List however it was not updating on ...
