Integration failure : : 'G/L account xxx needs DR assignment for dimension x; fill in DR-related
 iVend 6.6   integrated with SAPB1
There is integration failure from iVend to SAPB1 when Incoming Payment document is getting created in SAPB1 from iVend Integration
Error Message : G/L account xxx needs DR assignment for dimension x; fill in DR-related fields
The problem is not related with iVend it seems like a G/L account mapping issue in SAP B1, please consult with your SAP Partner/Expert.
You may check below link which will describe you the things on which you need to work in SAP B1.
Not Applicable
Integration failure : G/L account is missing
Version: Not the specific one Issue: Failed records in Integration monitor with below error: "System.Exception DI [INV1.AcctCode][line 3] , 'G/L account is missing (3)' at ReplicationSBOIntegrationWinSer.IntegrationObjects" Resolution: Please check ...
Integration error for Transaction "G/L Account is missing"
Environment : iVend 6.6 with SAPB1 Problem Statement : Failed records in Integration monitor with below error: "System.Exception DI [INV1.AcctCode][line 3] , 'G/L account is missing (3)' at ReplicationSBOIntegrationWinSer.IntegrationObjects" ...
SAP Business One - iVend Retail Integration Points
Wrong Tender G/L account is getting impacted in SAP
Environment: Not version-specific Problem Statement: Wrong Tender G/L account is impacting in SAP, Customer needs to map different G/L account for a specific warehouse rather than main retail account (Enterprise level) however it is not working. ...
Sale record stuck in integration :DI: [RIN1.AcctCode][line: 1] G/L account is missing (1)
Product Version: iVend 6.5 update 6 Patch 2, with SAP B1 Problem Statement: Sale Transaction with both, Sale and Sale return as line items, stuck in integration. Symptom: Integration record stuck with below error: System.Exception: DI: ...
