Index was outside the bounds of the array
iVend 6.5 SAP B1 9.3
Customer has lots of error in the integration monitor.
1496 SAP - iVend and 8 iVend to SAP. All error in SAP to iVend are "index was outside the bounds of the array"
Proposed solution:
To fix the issue we replaced the older version of Integration exe for iVend version 6.5 6 with latest one and the records were cleared
Steps/ Constraints:
Not Applicable
********* Internal CitiXsys********* Product version iVend 6.5 With SAP 9.3 Problem Statement Customer has lots of error in the integration monitor. 1496 SAP - iVend and 8 iVend to SAP. All error in SAP to iVend are "index was outside the bounds of ...
iVend 6.6 Performance Issues-Required SQL Index
This KM is for Internal Purpose Only for CitiXsys Environment: iVend 6.6 Problem Statement: We have noticed that customers are facing performance issues with iVend 6.6. Symptoms: Environment Specific Resolution/Work Around: Technical Team has checked ...
Check NONCLUSTERED INDEX created or Not on any iVend tables
Environment : iVend Version 6.6 with SAPB1 9.2 Problem Statement: How to check that NONCLUSTERED INDEX created on any iVend tables Symptoms : How to check that NONCLUSTERED INDEX created on any iVend tables Resolution/Work Around : Run the Below ...
Getting an error "commit failed object type transaction sale item key"key number" while completing
Problem Statement :- Getting an error "commit failed object type transaction sale item key"key number" while completing the sale transaction Solution:- Check the db fragmentation by using below query SELECT top 100 OBJECT_NAME(i.OBJECT_ID) AS ...
Delay in Management console login time and reports
Environment: iVend 6.6 Patch 7747 Problem Description: Delay in Management console login time & reports. Scenario: Clients facing an unusual time to login Management Console (dos mode screen also appears) and the reports taking more time to generate ...
