Check NONCLUSTERED INDEX created or Not on any iVend tables
iVend Version 6.6 with SAPB1 9.2
Problem Statement:
How to check that NONCLUSTERED INDEX created on any iVend tables
Symptoms :
Resolution/Work Around :
Run the Below query and check the output.
select o.name as Table_Name,i.name as Index_Name,I.type_desc
from sys.indexes as I with (nolock) inner join sys.objects as O with (nolock) on I.object_id=O.object_id
where i.type_desc='NONCLUSTERED' order by Table_Name desc
    • iVend 6.6 Performance Issues-Required SQL Index
      This KM is for Internal Purpose Only for CitiXsys Environment: iVend 6.6 Problem Statement: We have noticed that customers are facing performance issues with iVend 6.6. Symptoms: Environment Specific Resolution/Work Around: Technical Team has checked ...
    • Database health check & Optimization steps
      Steps and walkthrough to do a health check and optimization of iVend database. The entire process broadly consists of 8 steps: Step 1: Take Backup of DB. Open SQL Server Management Studio Express and connect to the SQL server. Expand Databases. ...
    • POINTS TO CHECK POS PERFORMANCE
      Checkpoints There are below check points on POS Performance : 1.Collect the data from Customer in a word document. ( Refer the attached file) 2.CHECK SYSTEM RAM SIZE : Check POS System RAM This should be as Per Ivend Hardware Guide (Take Screenshot ...
    • Customer Created in Magento Doesn't integrate to iVend.
      Problem statement: Customer Created in Magento Doesn’t integrate to iVend. Cause: Possible cause is the default setting for customer integration. If Create Customer in iVend is selected as “On First order” in iVend Magento Settings then such issue ...
