index was outside the bounds of the array
********* Internal CitiXsys*********
Product version
iVend 6.5 With SAP 9.3
Customer has lots of error in the integration monitor. 1496 SAP - iVend and 8 iVend to SAP.
All error in SAP to iVend are "index was outside the bounds of the array"
Proposed solution
To fix the issue we replaced the older version of Integration exe for iVend version 6.5 6 with latest one and the records were cleared
Steps/ Constraints
Not Applicable
Index was outside the bounds of the array
Environment: iVend 6.5 SAP B1 9.3 Problem Statement: Customer has lots of error in the integration monitor. 1496 SAP - iVend and 8 iVend to SAP. All error in SAP to iVend are "index was outside the bounds of the array" Proposed solution: To fix the ...
iVend 6.6 Performance Issues-Required SQL Index
This KM is for Internal Purpose Only for CitiXsys Environment: iVend 6.6 Problem Statement: We have noticed that customers are facing performance issues with iVend 6.6. Symptoms: Environment Specific Resolution/Work Around: Technical Team has checked ...
Check NONCLUSTERED INDEX created or Not on any iVend tables
Environment : iVend Version 6.6 with SAPB1 9.2 Problem Statement: How to check that NONCLUSTERED INDEX created on any iVend tables Symptoms : How to check that NONCLUSTERED INDEX created on any iVend tables Resolution/Work Around : Run the Below ...
Getting an error "commit failed object type transaction sale item key"key number" while completing
Problem Statement :- Getting an error "commit failed object type transaction sale item key"key number" while completing the sale transaction Solution:- Check the db fragmentation by using below query SELECT top 100 OBJECT_NAME(i.OBJECT_ID) AS ...
Delay in Management console login time and reports
Environment: iVend 6.6 Patch 7747 Problem Description: Delay in Management console login time & reports. Scenario: Clients facing an unusual time to login Management Console (dos mode screen also appears) and the reports taking more time to generate ...
